Let's see what your thoughts are on this one: When I use a timing light on my motor (stock 1.3), I notice that every few seconds the timing mark fails to appear for a split second (guessing one rev). I thought it was my timing light at first, so I bought a new one. Same result. I don't really know why, but I decided to put the timing light pick-up on the other wires just to see if I could see the timing mark from different angles and see if they skipped. What I ended up seeing is that when it missed on #1, it appeared to be firing on #4...in other words, if I put the timing light pick-up on the #4 wire, every few seconds it flashes with the timing mark at 10 btcd (where #1 should be). Since I first saw this problem I have put in a new distributor, cap, wires, plugs, timing belt and yes I checked for a loose crank pulley...the only thing I haven't replaced is the coil. I have re-routed and separated the plug wires. It actually runs pretty good, but it still does it and it makes me crazy
Any ideas?
