I bought a set of T.T. gears. Does the output gear you are talking about have 2 holes drilled in it (the old factory gear)? If so the new replacement has 2 grooves on the top and 2 grooves on the bottom, kinda looks like an = sign.....
I should put more grooves in it going the other way?
Sorry, I'm just a little lost here. I understand the concept of grooving it, but want to make sure we are talking about the same part.
I didn't receive any info with the gears about any break in process or oil. I usually use the cheap stuff from the auto parts store but I want to use something better with these gears. These gears cost as much as the Tracker did when I bought it!!!
