You will use the timing from the 95.I have a 96 and run mine a few degrees in advance of what the timing info under the hood recommends (5 degrees). Otherwise the engine tends to have a bit of a flat spot when accelerating between 2K and 3K on the RPM range. I believe Wildgoody actually runs his between 10-12 degree advanced, but I don't know if that is with the diagnostic bit set or just when the vehicle is at idle.
