taking the doors off, bolts are stuck GOOD and tight.
  • 23 Replies
  • 6092 Views
Bobthebiker
« on: May 16, 2010, 12:49:04 PM »
alrigt, Im attempting to remove the doors today,  right now I'm at the point of drilling the bolts out and replacing them with some other form of bolt, like a hex head because so far I've started to round out a few, snapped a screwdriver, and frankly, I just cant come up with a better way.
they're not rusted in that I can tell,  but they sure the hell dont want to com out.   anyone got any good ideas before I take the drillbit and punch a hole clean through?
Offline elf
  • 102
  • ~~~ZUKIUP~~~
Re: taking the doors off, bolts are stuck GOOD and tight.
« Reply #1 on: May 16, 2010, 02:31:04 PM »
When i first removed my doors i had to use a impact screwdriver the kind you hold and hit with a hammer the vibration was enough to to break to the screw lose.
Suzuzi:: Squeeze between the shit they cant crawl over
Bobthebiker
« Reply #2 on: May 16, 2010, 04:03:07 PM »
I got em.  ended up destroying all the screws, but I got em.   I simply got mad and used my drill, which evidently made enough vibration n a few,   the rest I used a chisel and 3lb sledge as an impact driver on.  worked.
Offline elf
  • 102
  • ~~~ZUKIUP~~~
« Reply #3 on: May 16, 2010, 06:09:13 PM »
hope your planning on cutting the hinges so you can just pop the doors off if ya want. makes summer alot more fun!!
Bobthebiker
« Reply #4 on: May 16, 2010, 06:15:39 PM »
yep. I absolutely am.   LOVE how it feels without the doors.  I do a lot of jump in and jump out kind of stuff, and opening doors gets old.
Offline oak_raid
  • 193
« Reply #5 on: May 17, 2010, 08:18:46 AM »
the impact screwdriver is what I used also.
Offline lv2fsh
  • 312
  • 19
« Reply #6 on: May 17, 2010, 10:04:53 AM »
I always used a combination of a small pair of vise grips and a screwdriver. If you're careful, you can grab the outside of the screw with the vise grips and help turn it with screwdriver. Haven't had to dril one yet.
Bobthebiker
« Reply #7 on: May 17, 2010, 10:36:21 AM »
These phillips head screws are just poorly planned, because really you have to destroy them just to remove em.   they're way too soft.      my luck with grabbing the buggers with pliers of ANY sort is pretty much crap until I have it like halfway out so I can get a solid bite.
« Reply #8 on: May 17, 2010, 12:32:41 PM »
One trick is to take a cutting wheel on your grinder and cutting a new notch in the screws.  Then you can use a large flat-head screwdriver to run the screws out.
The other is to use a large Phillips screw drive and a hammer.  Smack it into place a few times with the hammer before trying to turn.
Bobthebiker
« Reply #9 on: May 17, 2010, 12:47:47 PM »
tried both. just rounded out the head with the phillips,  and BROKE my favorite flathead.  which pushed me over the edge and I just said  **** IT! YOU'RE GETTING DESTROYED!
Offline jow003
  • 403
« Reply #10 on: May 18, 2010, 06:09:30 AM »
im havin the same prob.  i bought a impact driver for this specific prob and to no avail! i cant get even one to budge.  i thought about just taking a cutter to the top hinge arm with em attached but i may need to try this sledge idea >:D...
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #11 on: May 18, 2010, 11:11:03 AM »
hold a soldering iron on it to heat, then chisel counter-clockwise
« Reply #12 on: May 18, 2010, 03:29:23 PM »
Plan A.......impact driver.
Plan B.......weld a nut onto the screw head.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #13 on: May 18, 2010, 08:47:05 PM »
Plan C...... Heat the bolt head with a propane torch like one would use to solder copper pipe together until the paint bubbles.  This breaks down the threadlock and causes the bolts to unthread fairly easily.
I have successfully done Plan B on the door bolts but I could never get Plan A to work.  I always ended up buggering the head.
Ack
« Reply #14 on: May 20, 2010, 07:56:45 AM »
Plan B also performs Plan C, so regardless you should
be able to get them out after that
