ELECRIC FUEL PUMP Q'S
  • 1139 Views
Offline war_paint
  • 9
« on: July 18, 2011, 07:32:53 PM »
I NEED TO KNOW WHERE TO FIND KEY ON POWER
ALSO WHAT PSI DO I SET MY FUEL PRESSURE REGULATOR AT FOR A CV CARB
88' SAMURAI (FULLY BUILT 1.3L W/ POWER STEERING ,35"TIRES , RUF SPRING OVER W/TOYOTA AXLES & MISSING LINK SHACKLES, .529 GEARS & 6.5:1 TRANSFER CASE)
Re: ELECRIC FUEL PUMP Q'S
« Reply #1 on: July 18, 2011, 09:12:07 PM »
Key on power would be you use a test light at the fuse block, tho I have
power on with key at the lighter socket, not sure on your truck,
the pressure should be 3-5 PSI for most carbs, what is a CV carb?
  • 4314
  • 167
« Reply #2 on: July 19, 2011, 05:45:24 AM »
The lighter socket would normally be ACC ON rather than KEY ON - depending on why you need it, it could make a difference - seeing as the subject line was electric fuel pump q's, I assume he wants to power a fuel pump, ACC ON would not be advisable - the easiest place to find KEY ON is - ta-da - the ignition switch itself.
There are other places, but since you haven't identified the vehicle - that limits the scope of our answers.
A CV carb is a constant vacuum - also known as constant depression - for US & Canada, think Harley Davidson (the MYSIDE conversions), or if you're UK or similar, an SU or a Stromberg CD.
« Last Edit: July 19, 2011, 05:47:59 AM by fordem »
« Reply #3 on: July 19, 2011, 08:45:17 AM »
Ohh, those carbs, didn't know they called them that thanks :)
And now I think about it the lighter socket powers down while cranking
so ya, not a good spot for a fuel pump
Offline war_paint
  • 9
« Reply #4 on: July 28, 2011, 09:15:28 AM »
ok well thank you for your help i will be putting it together this weekend
so ill tell you how it goes
