199psi is factory spec.
170psi is the service limit.
150psi....I've had a few 1.3s and 1.6s that have had 150ish compression across all cylinders and they ran great.
My suggestion, as long as it is still running good, don't worry about it. Make sure your valves are adjusted correctly and not too tight (that can cause low compression readings and burnt valves).
