Strut bolts. -- looks like I am drilling them out.. Everything else has failed.
  • 1694 Views
Offline thebanjoman
  • 72
I'm only 50% for the removal of 4 stud bolts on my 97 sidekick sport to replace the struts..   I got the 2 bottom ones off. I had broke both of the top ones off.
I was able to get the nut off but broke off the head of the bolt on both sides trying to loosen them up.suzuki
PB Blaster - several applications over a few days.  - NOPE
Acetone/ATF Mix.  - several applications over a few days -- NOPE
Oxyacetylene torch. Bolts red hot  and a smack with a hammer - NOPE
Oxyacetylene torch. Bolts red hot - Sprayed with Actone/Atf mix to try and get it to 'suck in;  - NOPE
Oxyacetylene torch. Bolts red hot - Sprayed water to shock the bolt to try and loosen it up.  - NOPE
The only thing I haven't tried in my bag of tricks is Oxyacetylene torch. Bolts red hot and beeswax. Because I don't have any.
I cut off the strut with a 3" cutter to have full access and to get the heat directly where it needed.
I see I have 2 options.  -
Drill the bolts out  royal pain and lots of time.
Hit the yards and pull 2 new spindles and use them.
I don't know what else to try.
I've been at it for several days.
If you pay packing and shipping, I will send you two spindles and the bolts. I think I have everything still.
Offline thebanjoman
  • 72
This is a  JLX with 4 Wheel ABS.      I'd love to get some less rusty backing plates as well for this.
PM sent.
Mine is also a JLX with 4 wheel ABS.  Let me know what other parts you need.  I have been swapping any parts that are better on to my new one, but I have lots of parts that are going to the scrapper soon.
Offline thebanjoman
  • 72
Thank you.   PM Sent.
  • 4314
  • 167
Curiosity question - are/were the top bolts camber adjusting bolts?
Offline thebanjoman
  • 72
Not that I know of. . They would probably be easier to get out if they were.  There would be some void in the space and it's solid.
Surprised that they gave me such a fit. Usually getting them red hot loosens them up.
