I already know I need a new sheet on the t case, and what I need to do to replace that, but really my question is, has anyone ever seen that sheet just disintegrate over time?
Reason I ask is, the other day I went to autozone and had it in 4wd, soon as I went to go back to 2wd, it got stuck in neutral, and I had to tear the shifter out only to find the shifter sheet more or less just crumbled in there. I've got no idea if this is normal of the stock sheet, or if this is some really severe issue.
I'm positive I need to clean the material left from that out, and change the t case oil now for sure(I was due to do this awhile back anyhow) so at least I'm fairly aware of what I need to replace/change/flush. Right now, I have no bad noises coming from the case, which isnt surprising since I'm generally pretty gentle on it.
