Transfer Case Vibrating/Shaking
elprincipal
11
November 02, 2009, 04:24:58 PM »
I bought a Sammy that has a vibration in the transfer case up to 25 mph. Do the transfer case arms come in one size fits all? What brackets/arms/mounts would you recommend and why?
Last Edit: November 02, 2009, 04:28:20 PM by elprincipal
Drone637
8121
116
Evil Cow
Re: Transfer Case Vibrating/Shaking
November 03, 2009, 10:52:53 AM »
All the Sammy's have the same t-case mounts. You may want to pull your t-case off and see if the long mount has been twisted up.
As for after-market kids I am a fan of the Snatch from ZOR. One of the guys in the club just picked on up and it is one of the few that make removing the t-case easier then stock due to it's design. But you really can't go wrong with any of the products out there.
You might also want to check your u-joints and bolts on the jack-shaft between your t-case and the transmission.
zukimoo
330
2
November 03, 2009, 04:52:58 PM »
check the drive shaft bolts, u-joints and the get under the vehicle and push up on the t-case. the mounts break all the time. Look at the rear tranny mounts...it's very weak too and can cause some vibs.
06 Baja Buggy
