Did you have to attach the regulator to the glass? I haven't worked with this specific vehicle, but, f I recall correctly, having the regulator positioned incorrectly on the glass can cause problems similar to those you are describing - some fixtures allow you to slide the regulator along the bottom of the glass, if yours does, try moving it slightly in either direction.
