Look at the core. Lots of times aftermarket replacement radiators will only have a single, larger row...the same width as the 2 rows in the OEM. If your rig is in any kind of good repair, I would think you should not have much problem. Now, no off-roading, but the last summer I had my Kick on the road I drove it daily, and a fair portion of the time pulling a trailer, with no fan whatsoever, and never had an overheating problem. This was also in Texas heat, many days in triple digit temps.
Now if it is a single row, same size as the individual rows in the original, that could be problematic. Which is yours?
