1992 Sidekick JLX
  • 0 Replies
  • 414 Views
Offline RJkick
  • 631
1992 Sidekick JLX
« on: March 18, 2024, 02:18:17 PM »
I have been having some problems with the inner axle on the left \ Driver's side coming out.  The axle looks OK to me but that doesn't mean much.  It has the circlip on the end and when installing it goes almost all the way and then requires a little tap to install completely.  I added a 15" limit strap and will next look at full droop and stuff to see if the axle shaft pops out.
Any thoughts as to why this would happen?
Need a new inner as too warn out or something like that?
