wiring.....
  • 7 Replies
  • 2332 Views
Offline jow003
  • 403
wiring.....
« on: May 06, 2010, 05:59:29 AM »
In the past week my 87 Samurai all the sudden wouldnt start, turn over, or even click.  my first thought is that its a prob with the wiring, does anyone know a company that sells a wiring harness or doe anyone have any suggestions as to something else it might be?  The battery is basically brand new.
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: wiring.....
« Reply #1 on: May 06, 2010, 07:58:15 AM »
Make sure to clean the battery clamps well, bright is good, and
get a battery terminal brush and some spray cleaner too.
Other than that, you can check the big fuses close to the battery
and the fuses under the dash. Also check the body ground, that's
the small wire from the neg terminal on the battery cable
Good Luck
  • 4320
  • 167
Re: wiring.....
« Reply #2 on: May 06, 2010, 08:06:20 AM »
Just so that you know - wiring harnesses generally don't just fail - in fact the chances of your new battery failing are actually higher than the harness failing, so do the basic troubleshooting first.
Turn the headlights on - are they bright?  Have someone try to crank the engine whilst you watch the lights, they should not dim significantly or go out when you crank, those are signs of a failed or flat battery, or a poor connection.
Bobthebiker
Re: wiring.....
« Reply #3 on: May 06, 2010, 05:35:58 PM »
a battery cable being dead is also a solid possibility if you have ZERO power of any sort.   I owned an old ford like that once, and thats what I had to do was change a cable from the negative terminal to engine.
Re: wiring.....
« Reply #4 on: May 06, 2010, 11:38:04 PM »
Good call Bob, I had not considered the acid could have
eaten all the way through the cable causing no power.
Offline jow003
  • 403
Re: wiring.....
« Reply #5 on: May 11, 2010, 05:56:33 AM »
so over the weekend i got to work on it.... as it turns out my brother who said it was the wiring doesnt know as much as he thought, it was the alternator i put in it a few years that went bad which absolutely and completely drained the battery so after spending a small fortune (atleast for me) getting new alt/batt it runs just as it did, now my only problem is gettin the carb tweaked from 10 feet in elevation to 6700.  any ideas?
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: wiring.....
« Reply #6 on: May 19, 2010, 07:40:37 PM »
uhh, EFI would do wonders for that range  ;)
Offline jow003
  • 403
Re: wiring.....
« Reply #7 on: May 20, 2010, 06:06:03 AM »
haha ya, got an extra one layin around? :P
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
