Is this the valve under the hood? Unless there is something wanky, Sidekick and Tracker parts should interchange. Where is it leaking on the valve? Is it leaking around a fitting?
Is yours equipped with a height sensing proportioning valve? If it is, there will be a lever attached to the body or frame of the vehicle that attaches to the proportioning valve. Have you been able to at least make it home safely?
Tomorrow I will check out my parts rig. It has the height sensing prop valve. If you will pay the shipping, it is yours. I won't have any use for it.
