Reviving an old thread regarding 2.3 swap wiring problems. I bought a 2000 tracker 2 door that originally had a 1.6L / 5 speed manual in it. The previous owner had swapped a 2.0L/4 speed auto
into it. I already had a 2004 Aerio 2.3 that I had bought for my '96 grasshopper but decided to put it in the 2000 since it was going to be primarily a sand dune rig. So the swap went OK I used basically the bare longblock from the 2.3 with all the 2.0 externals and harness. It is very peppy and has great low end torque. The problem is when it hits 5000 rpm it acts like a rev limiter
and starts cutting out. I don't know what previous owner did about under dash wiring and connecting the 2.0 ECU/TCU up with the original 1.6 harness. I even bought another 2.0/auto ECU
and put it in, but still has same problem. Looks like I need wiring diagrams for both 1.6 and 2.0 vehicles so I can figure this out, but thought somebody else may have run into this same issue.
