no erlectrical to anything
  • 1 Replies
  • 1531 Views
Offline rerunhd48
« on: June 23, 2015, 05:46:45 AM »
I have a 1988 jx and yesterday while driving just went dead, I have no power to anything, horn , lights, radio, nothing! Battery is good, power to fuse block is good, all connections are solid as far as I can tell, WTH happened. Could this be ignition switch? I really hope this is a problem someone knows a solution for.
Re: no erlectrical to anything
« Reply #1 on: June 23, 2015, 09:42:25 AM »
Think about it some more - do the horn & lights normally require the key?
Battery, battery connections or main fuse - one of the three - and don't just eyeball the block and shake the connections, they have been known to corrode & burn where you can't see it - disconnect the battery, unbolt the fuse block and remove it, check it with a meter if necessary.
