transmission shifter problems
  • 3451 Views
Offline scooterszuk
  • 20
« on: June 16, 2009, 09:25:41 AM »
fellows when I shift to 3rd gear, my shifter gets stuck and I have to take boot off and adjust the shifter back into position then i can change gears again, I notice it has gotten sloppy shifting, not crisp to engauge anymore. My question is, is the linkage in the transmission screwed or is it the shifter worn out?
Offline scooterszuk
  • 20
Re: transmission shifter problems
« Reply #1 on: June 16, 2009, 09:29:04 AM »
Vehicle is a 1988 suzuki samurai tin top.
  • 6555
  • 64
« Reply #2 on: June 16, 2009, 10:16:12 AM »
There is a shift pin that breaks on the Samurai Transmissions. In our Gear Guide section you will find an article that show one of the ways to fix the problem.
http://www.zukiworld.com/month_090102/feature_hawkshifterpinfix.htm
Good Luck, Eric
Offline scooterszuk
  • 20
« Reply #3 on: June 16, 2009, 01:32:54 PM »
thanks have ordered 1
