I understand the movement that comes with the rubber, its no urethane, nor does it need to be.
But this is way to much movement. A completely separated (old) tranny mount didn't allow for this much movement. The shifter moves maybe 3inchs so maybe everything is moving half an inch or so. But the clutch really lets out a whine under some good load. This shouldn't be.
I guess I'll just ghetto rig it and put a block of wood between the transmission and transmission tunnel. Awesome!
Never mind, I'm just a moron. Driver side motor mount has been sliced. I was unable to see it but started pryin around with a crowbar and found it.
