« Reply #3 on: July 09, 2011, 06:05:50 PM »
Try running a jumper wire down to starter solenoid, then when ready to start apply 12 volts off the battery.
- If it starts just fine you have wiring issues, not getting 12 volts to solenoid.
- If it still clicks you have starter or solenoid issues.
This should get you pointed in right direction.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
