I thought the 16V engine came with the 4 speed auto
which is a Toyota corp built
tranny, I swapped to 235 75 15s and loved it, no gear mods, and it corrected the speedo
to read 100% right, mind you this was on an 89 8V with the 4.62s, these days I run 33 13.5 15
swamper LTBs and a set of highly sought after 5.83 diff gears, but if you swapped out the 5.12s
you shouls gain a little power on the road, swap out the trans speedo drive gear too, or at least
get it from the donor vehicle to correct your speedo readout if it's wrong
