Low beams not working
  • 6187 Views
Offline dcheis12
« on: September 12, 2010, 09:13:15 PM »
Hey all I have 1988 samurai that my uncle is letting me use. The only problem is I cant pass inspection because the low beams will not work the high beams work perfectly fine.
Any ideas on what it could be and possible fixes?
     thanks in advance
Re: Low beams not working
« Reply #1 on: September 12, 2010, 09:42:49 PM »
Bad head lamps, check the fuses, but I don't think they were fused
Offline dcheis12
« Reply #2 on: September 12, 2010, 11:56:35 PM »
Just replaced the lamps and its the same fuse for both high and low beams if i remember correctly.
  • 4312
  • 167
« Reply #3 on: September 13, 2010, 07:45:06 AM »
Check the wiring between the lights and the combo switch - there's either a burnt or broken wire.
« Reply #4 on: September 13, 2010, 02:45:27 PM »
It might also be a relay issue, as high beams and low beams run off of a separate relay.
In my SJ-410 the switch for the beams went out and I lost the low beams.  I was able to take it apart and build the switch returning it to working order.
  • 4312
  • 167
« Reply #5 on: September 14, 2010, 05:20:47 AM »
As I recall ...
On a Samurai - there are no headlight relays
On a SideKick - there are no headlight relays
On a Grand Vitara - the headlights relays turn the lights on/off, buit do not select high/low beam.
« Reply #6 on: September 14, 2010, 01:41:10 PM »
As I recall ...
I thought there was a relay on the SJ series, but it looks like your right.  There is a R/W wire coming from dash for the low beams and a R wire for the high.
http://www.4x4.in.th/manual_sj413/chapter23.pdf
