Loss of Power When Cold
  • 2863 Views
Offline Thirty-Nine
  • 284
    • Subcompact Culture
« on: December 30, 2015, 02:15:51 PM »
I've read through a number of threads here over time talking about this same issue. When cold, power loss when accelerating above 2,000/2,500 RPM. Seems to go away when warmed up.
My rig has 167,000 miles on it. Plugs, rotor, cap, wires, timing belt/H2O pump, upper oxygen sensor done about 30,000 miles ago. Compression test done a couple years ago, still decent. However, it's been hesitating for years (since at least 2011), but seems worse when it's cold outside (today was in the 30s, and I really noticed it), and seems to be pretty bad now.
I recently fixed my CEL regarding my EGR valve (blocked passageways), so I don't think it's that. I did run a CEL for about 4,000 miles. Could that have fouled the plugs or O2 sensor?
I seem to have taken a bit of a hit in mileage, too. Even with bumper, winch, roof rack, 235 mud terrains, I used to get 22/23 MPG. Now it's more like 19 or 20.
Any other suggestions? Test ECT?
  • 4314
  • 167
Re: Loss of Power When Cold
« Reply #1 on: December 30, 2015, 06:04:27 PM »
I would start with wet & dry compression tests...
Offline Thirty-Nine
  • 284
« Reply #2 on: December 31, 2015, 11:51:25 AM »
I did a compression test, but I think it was a few years back. Numbers were fine for a rig with 145,000 on the clock. Time flies, though.
  • 4314
  • 167
« Reply #3 on: December 31, 2015, 01:35:51 PM »
You mentioned it, do another one.
Compression numbers are lower on a cold engine than on a hot one, pistons expand, rings seal better - your symptoms are those of a worn engine, and at 167,000 miles, that might be your problem.
Offline Thirty-Nine
  • 284
« Reply #4 on: December 31, 2015, 01:54:05 PM »
10-4.
Well, I just had the transmission rebuilt. Hope the engine isn't next! Oh well, it's just money. [emoji1]
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #5 on: January 02, 2016, 06:21:42 PM »
Install a 2.3 liter engine in it like Eric just did on his sport.   That would turn your two-door into a beast.
« Last Edit: January 05, 2016, 02:01:07 PM by nprecon »
Offline Thirty-Nine
  • 284
« Reply #6 on: January 04, 2016, 12:32:25 PM »
Install a 2.3 liter engine in it like Eric just did on his sport.   That would turn your two-door into a beat.
Yeah, that'd be pretty sweet.
