trans oil '93 geo
  • 1344 Views
Offline badkat
  • 6
trans oil '93 geo
« on: June 10, 2010, 01:29:27 PM »
just recently put clutch in i went to put oil that we caught back in   wouldn't hold but half of it started running out
is the plug on side of trans the only place where you fill it   or recon somebody just over filled it
                                                 thanks
Offline badkat
  • 6
Re: trans oil '93 geo
« Reply #1 on: June 11, 2010, 11:15:05 AM »
anybody know
Offline c10long
  • 39
« Reply #2 on: June 14, 2010, 01:26:49 PM »
80-90w gear oil.  non-synthetic GL-4.  is what the factory calls for.  GL-4 has been replaced with gl-5.  So, GL-5.  Synthetic oil has smaller particals and some say it can seep out through your seals.    personal preference.
Offline badkat
  • 6
« Reply #3 on: June 14, 2010, 09:35:06 PM »
also iwent wheeling  and the clutch  started not disingaugeing al the way i tighting the cable  till it ran   out still not right
new clutch any susgesting?
Offline c10long
  • 39
« Reply #4 on: June 15, 2010, 06:20:52 AM »
check the clutch arm.  the part that connects to the transmission with the cable on the bottom.  make sure that isn't stripped or it slipped.
Offline badkat
  • 6
« Reply #5 on: June 15, 2010, 09:55:52 AM »
thanks for your help man!!!!   i found the outer part cable   was   broke making it not pull the arm far anough
« Reply #6 on: June 18, 2010, 09:41:20 AM »
As for the oil coming out of the side, that means it's full.  You only fill it up to the fill plug, same with the transfer case.  :)
