yea i made sure it turned smooth...pulled it off and checked it, relubed the shaft it slides on, im a ase cert tech not that means a whole lot, just new to samurais the hella noise this thing is making doesnt sound like anything ive ever heard come from a throwout bearing, just didnt know if this noise was a common problem, ive done alot of searchs and mine is the same as alot of others no noise in 4th gear must be a trans issue, ordering a rebuild kit on monday, as for as the plate being used as a spacer for the starter, it starts fine with no issues
