spark problems. 86 samurai. HELP!!!!!!!!!!!!
  • 12 Replies
  • 2139 Views
« on: April 03, 2010, 07:58:47 PM »
i got a samurai with a stock 1.3 motor in it. i was going wheelin one day and my motor just died on me when i was goin threw a hole. its not getting any spark. i checked the resistance on my coil and my distributer and ther both fine. i replaced the computer and that isnt the problem. im getting power to everything but im not getting any spark out of my coil. i tore apart my wireing harness to see if i can fined any bad wires and there wasnt any. im compleatly stumped on this one.
Bobthebiker
Re: spark problems. 86 samurai. HELP!!!!!!!!!!!!
« Reply #1 on: April 03, 2010, 08:14:13 PM »
only thing I can think of that makes ANY sense is the coil on your firewall is DOA. is it original or aftermarket?
« Reply #2 on: April 03, 2010, 08:30:18 PM »
i just got a new coil for it
« Reply #3 on: April 03, 2010, 08:33:40 PM »
the coil tyhat was in it before was a msd 2 and that has a bad resistance reading so i replaced it . i have tryed 5 different coils. all good and all give me no spark
« Reply #4 on: April 03, 2010, 08:43:05 PM »
i even tryed hookin my batery right to my coil for a deffinate ground. im getting 12volts to the coil but when i crank it over it drops to 10volts. idk if that helps at all
Offline SnowSammi
  • 31
« Reply #5 on: April 04, 2010, 12:16:49 AM »
This may sound silly to ask but did you check your coil wire?  it's easy to over look
 when you get frustrated >:(
« Last Edit: April 04, 2010, 12:18:22 AM by SnowSammi »
87 Samurai: OME springs & shocks, 30" Cepek mountain cat tires, K&N air filter, 6:4.1T-Case gears.
« Reply #6 on: April 04, 2010, 11:47:28 AM »
yes i checked my coil wires. i have power getting to my coil and distributer. i am not getting any spark at all. HELP!!!!!!!!!!!!!!!!
« Reply #7 on: April 04, 2010, 11:58:38 AM »
You need to replace the ignitor in the distributor,
probably easier to just get a used distributor for it
« Reply #8 on: April 04, 2010, 12:18:32 PM »
i got an new used distibuter for it already. i checked the resistance in it and it meet requierments in my samurai book. i will re test it. if its good then what else could be the problems????
Bobthebiker
« Reply #9 on: April 04, 2010, 01:24:56 PM »
thats most of your problem, you're buying USED parts.  buy BRAND NEW and it will probably work.  used ignition parts is pretty much a gamble, it may work, it may not.  you just dont know.  resistance tests even dont make much of a difference to me.
« Reply #10 on: April 04, 2010, 01:34:19 PM »
i priced a new ditributer out and its 400. i know i should buy new parts and its a gamble but 400 for a part that might not be the problem is a gamble to. its fustrating
« Reply #11 on: April 04, 2010, 01:50:54 PM »
im not getting any spark out of the coil. i have power to my coil but no spark. i think my distributer is fine. i cant know its my distributer because if i dont get any spark out of the coil how will i know the distibuter is bad or good? i have to get power out of my coil first to get power to my distibuter. why am i not getting any power out of my coil if my coil is good and i got power going to my coil???????
Bobthebiker
« Reply #12 on: April 04, 2010, 03:23:30 PM »
check your primary/secondary wires going TO the coil on the vehicle harness. I'm betting you're missing something REDICULOUSLY simple.  might even just be a fuse in the panel under the dash.
