Seeming "low " and looking like a grocery getter are two different things. A lower center of gravity is a far better thing to have , imo, than being jacked up to the moon with no effective suspension, ie stiff. Some of the most awesome and rugged rigs I've seen were actually not that tall. Big rubber yes, but the suspension was designed to droop, or drop out from under the rig with just enough ground clearence under the frame and diffs ( again wheel and tire size related ) as needed. Bigger, well much bigger wheel wells, but check Eric's Liberty Overland built rig. That is about the nicest, big tire'd , streetable sas job I've seen. On 37's I believe, and sure don't look like any grocery getter.
