Location/access to Wiring in dashboard for door of Suzuki Grand Vitara
  • 1660 Views
My 2000 Suzuki Grand Vitara was a hit n run victim  >:(on Friday. We located a 2001 door at the junk yard.  ;) OOPS, the wire harness plugs are different! :P I am desperate; the owners manual is of no help and no one in Spokane that I know has a Suzuki shop manual. The mechanic doing the work is a jeep guy and is bashing suzuki's so I wanna get this done!
« Last Edit: November 11, 2009, 08:51:28 PM by ZukiChick2 »
  • 4312
  • 167
Re: Location/access to Wiring in dashboard for door of Suzuki Grand Vitara
« Reply #1 on: November 12, 2009, 04:47:09 AM »
Which door are we talking about?
Do the wire colors match up?
Can you salvage the harness from the original door?
There's not that much wiring in the doors - unless it's the driver's side door AND you have power everything - it shouldn't be that hard to figure out.
I took a quick look at the two diagrams - power mirrors, power locks, power windows - the wires appear to be the same color for both years, makes it a matter of either cutting & splicing or swapping the connector bodies across - assuming that they use similar pins.
As for location - there will either be a connector inside the door itself or for a front door look behind the kick panel, and a rear door it'll be at the base of the pillar - it's been awile since I had the carpets out of my GV
« Last Edit: November 12, 2009, 04:50:24 AM by fordem »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #2 on: November 16, 2009, 10:12:29 AM »
That's because he can't come up with a scheme to get you to Just Empty Every Pocket...
Jeep people scare me...    ::)
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
