What can i do for more power
  • 19 Replies
  • 3496 Views
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
Re: What can i do for more power
« Reply #15 on: September 27, 2012, 04:43:29 PM »
how many punds of boost are you guys running. does the turbo help alot? oh and what kind of milage are you getting with it?
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
Offline biker
  • 730
  • It's a sickness I tell ya
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline biker
  • 730
« Reply #17 on: September 27, 2012, 06:33:01 PM »
If my guage is correct I'm running up to 9lbs if I keep my foot in it. I need to find a 7 lb spring for it so it doesn't get away from me. As for mileage it doesn't seem to have changed much if I keep my foot out of the turbo, but that's kinda hard to do for a big kid like me >:D :laugh:
99 Vitara 2wd
10 Gr Vitara
  • 162
« Reply #18 on: September 27, 2012, 08:13:25 PM »
yeah i bet i looked at your build it would be hard especially with 36s haha
« Reply #19 on: September 28, 2012, 05:13:48 AM »
My turbo is limited to 6/7 lbs and I run it on a COMPLETELY stock engine, other than bigger injectors and alc/h20 injection. I'm running 32x11.5 BFG AT KO's through an auto trans with 5.12 final gearing. Pulls like a raped ape on boost, never a lack of power, and I can still average around 22/23 mpg, but I have to use premium. Now that it's all said and done there has been enough development of turbo setups for the 16V that knowledge of what and how is readily available. I built my own manifold and experimented with parts until I got a reliable setup. Now you can use our experience to almost bolt one together. IMO, you would still need to correct your final gearing though, either via the Undertaker or a couple of diff sets. If you make enough power to turn those 33's without the proper gearing, your probably making enough power to start breaking things. jmho.
