I'm going to recheck to make sure everything is plugged in
I reset both bottom to 0 and top to E with slot like the picture
I was setting the rotor to #1 so I will set it to #4 and see what happens
I know it is getting spark but it just doesn't seem like the cylinder ever ignites
Could the valves cause this if set incorrectly with the cam?
If you have the cam pulley on the cam, like in the pic, then it is on correctly.
If you were setting the rotor (distributor), to #1, then that is your problem. Set it to #4 and it will work, as long as you have everything else right.
You can have the distributor set wrong, and you will still get spark. The problem is, you don't get spark at the right time, so the engine won't run.
