The hubs are all the same, the spindle on a 2wd is plugged where the half
shaft goes thru to engage the lockout hub, and is also missing a brass support.
wheel bearings can be really tough to get loose to get the hub off, you might
see if you can get the hub wrench and take it with you to the wrecking yard
