Manual transmission fluid question...
WVzuk
181
January 07, 2016, 08:17:42 PM »
So today I changed the transmission fluid in my 94 kick. I noticed that there was only about 1-1.5 quarts that came out of the transmission. I have no idea how it was so low. I last changed the fluid a couple of years ago. I have a gear whine I've been bit concerned about so I decided to change the fluid again. I added Lucas oil stabilizer because I read that it helps quiet gear whine. Anyway I was able to get a little over 2 quarts in before the fluid began to drain back out of the fill hole.
The specs say the transmission holds 3.2 quarts. Is there always some still at a low point in the transmission so it doesn't all drain out?
Capt
738
28
LIFT IT ! .......Fat Chicks CAN'T JUMP !!
Re: Manual transmission fluid question...
January 22, 2016, 06:55:38 AM »
Check your spec sheet,
It may be in metric as in liters,
and I have seen translated versions for the right hand drive
using the Imperial Gallons, quarts, etc....
Just a thought
leelorr
3
ZUKIWORLD Online!
January 24, 2016, 07:29:18 AM »
I read that it holds 2.x quarts after a rebuild (dry), and 1.6 quarts when changing the fluid. I figured that this was because some of the fluid stays on the gears and case after you drain it...
WVzuk
181
Reply #3 on:
January 26, 2016, 06:49:35 AM »
Thanks for the replies. The website I got the info from was misprinted. It is in fact 3.2 pints or 1.6 quarts.
Ridjobradi
674
6
Reply #4 on:
January 26, 2016, 10:41:03 AM »
Thanks for following up with what you found.
