16" dodge ram wheels
dp728
5
June 11, 2010, 09:51:36 AM »
Hi, I'm super new to the sami world. I am trying to figure out how to build my rig.
1. want to do a spoa lift. (home built) I'm guessing that will give me 4" of lift?
2. was looking at rims and tires. has anyone try ed to use 16" dodge ram wheels w/5x5.5 bolt pattern?
maxxis makes a tire 255/85-16 (33.5 x 10 ) fits a 7" wheel.
these are probably crazy questions.
thanks for your time
Skyhiranger
3734
122
I don't buy, what I can build
Re: 16" dodge ram wheels
June 12, 2010, 07:24:21 AM »
The problem with the stock dodge wheels I have seen is that they have waaay to much backspacing for a samurai...which will cause the tires to rub the springs hard when turning.
Yeah, around 4" of lift, depending on what spring perches you use.
dp728
5
June 12, 2010, 08:16:18 PM »
thanks, for info. going w/33x9.5 on stock rims
