weber/pressure reg/fuel pump-2nd try
  • 1650 Views
« on: March 11, 2011, 08:40:16 AM »
Guys, my question got highjacked with a discussion of Bernoulli-no worries
After reading the discussion(s), still not sure:
1.   Will the stock mech pump, with a pressure reducer work?
1a. Or do I HAVE to/better idea to replace the fuel pump?
I got one regulator+fuel pump response
one: regulator and existing pump response
Thanks for the replies.
Jesse
  • 4314
  • 167
Re: weber/pressure reg/fuel pump-2nd try
« Reply #1 on: March 11, 2011, 10:24:13 AM »
Yes the stock pump will work - the location and type of pump are not really that critical (within reason - you wouldn't want a 70 psi fuel injection pump, but the stock mechanical pump is fine), what's important is that you reduce the delivery pressure to that required by the carburettor - and my apologies for derailing your thread.
« Reply #2 on: March 11, 2011, 03:41:53 PM »
No worries Fordem, you have also helped me through other issues.  I am thinking there is more than one way to skin this cat, I just did not pick up on the need to change the pump when adding a weber.  I did hear the pressure needed to be decreased with a reducer.
I greatly appreciate everyone's input/help and opinions.
If there is a reason the pump needs to be replaced, I need to hear it.  Once again I am off into uncharted territory which is very cool and value the input from others who have gained experience with these vehicles.
Thanks a ton,
JS
« Reply #3 on: March 13, 2011, 05:03:59 PM »
The stock fuel pump puts out 3-4 pounds of pressure, and I believe the Webber prefers around 2.  While it usually isn't an issue a lot of people will install a fuel pressure regulator in between the fuel pump and the Webber to keep it at the recommended pressure.
Offline Riverrat
  • 54
  • Diesel Boats Forever
« Reply #4 on: March 14, 2011, 11:36:27 AM »
Jesse
Jesse!
hendrixautospeed a seller on eBay, list a spectre fuel pressure regulator kit 1-5# for $22.99 shipped!!
Tried to link it, but must not know how. A simple little inline unit with preset notches that are supposed to be right on calibration!
Hope this helps!!
Riverrat
Jimmy
Offline rascott
  • 669
  • 15
« Reply #5 on: March 14, 2011, 01:18:13 PM »
empi makes a pressure regulator that gets a bad rap regularly, however i've used them (20+ years), with no problems, with webers(vw projects back then), including my suzuki with stock fuel pump.
i get them thru j c whitney.
