engine swap auto into a 5 speed Trcker
smife
179
4
June 20, 2010, 06:23:15 PM »
I have an 8 valve motor that came out of a running automatic. What needs to be done to put it into an 5 speed 8v tracker? Thanks guys, I did try searching first
wildgoody
8134
67
Re: engine swap auto into a 5 speed Trcker
June 20, 2010, 06:59:52 PM »
Swap out the flywheel from the 5 speed onto the auto tranny engine
and plug the auto trans vacuum port on the intake manifold, other than
that, I think you are good, could be some other little things, but nothing
major that I can think of
cj
1276
I drive a really big ATV
June 21, 2010, 04:49:42 PM »
I have just swapped an auto in to a replace a manual trans and what Wild said is pretty much it.
