So this is pretty funny. When I got to work, I headed for my Autodata Timing belt book 06Edition: In all Samurai and Sidekick years it states that the 1.3L is a interference engine with most likely cause of piston/valve contact. I wasn't convinced and went to the back of the book to read it's disclaimers. In fine print |removethispart|@ the bottome of the page, it reads: "Although the information contained within this volume has been obtained from sources generally thought to be reliable, no warranty can be made as to its accuracy or completeness, nor is any responsibility assumed by Autodata Publications Inc. Piece of shit, I paid good money from Matco for this info.
Anyways, I called Suzuki Tech Hotline and the dude told me it IS NOT INTEFERENCE or freewheeling, whatever you want to call it. Though I replace my t-belt on time, I do not have any experience in running it till it breaks and finding out the hard way, I choose to error on the caution side. My zuk means more to me then most other things and I will not risk anything. The only explination I can think of is most places I gathered my info was more then likely connected to some sort of parts company, in hopes of making a extra buck of someone! I do apologize for any misleading info/headache I may have caused.
