It sounds like you have lost the ground. Look for a broken wire, The OEM wiring is thinner than speaker wire !!!!!
Also check the tail light assembly, the ground wire is attached to the bulb socket, these get KRUDDY with rust.
Also do any of the other lights go out (OR ON) when you step on the brakes ? This is a sure sign
of a BAD GROUND.
CAPT
