Hey guys, i have a 96 sidekick 4 door. having issues with it starting. if i boost it, it starts fine. and will stay running forever. but sometimes when i shut it off it wont start back up until i boost it again. when i turn the key on i can hear the starter clicking but wont turn over. so i tested the battery and its holding a charge. and where it will stay running forever i figured the alternator must be putting out a charge (never confirmed yet tho) so i went out today to take a look and check the grounds via the old kick-fix information and i noticed a wire was off and it was routed towards the starter. but i cant find any other piece of wire and i cant find anything on the coloring. The wire is yellow, blue stripe, and brown dots.
this is the wire I'm talking about, it was hanging straight down from where it is in this picture
this is the other end of the wire, it goes into this connector
this may or may not be my starting issue, but i figure its something to go on. I thought it might be the Top of starter mount bolt main battery ground. Any help or recommendations would be great.
thanks
