pinion bearings and seals
  • 1 Replies
  • 1332 Views
Offline scooterszuk
  • 20
« on: July 06, 2009, 09:38:09 AM »
Hey guys and gals,
I use my 88 sammie tin top as a hunting rig. Just a quick 4 mile trip to town to gas up occasionally.
The south Ga mud and water has took its toll on the driveline, I replaced rear wheel bearings, front wheel bearings, brakes all the way around. Now I have a noise when I engauge 4 wheel drive, the alxe pinion bearing in front is making the noise.  It has play you can detect when you grab driveshaft. Can you find just the kit to repair the pinion bearing and seal for front and rear. I don't want to do a complete overhaul, this sammie only gets 30 miles a month tops on it. Thanks for input!!
Re: pinion bearings and seals
« Reply #1 on: July 12, 2009, 10:23:39 AM »
Call trail tough, hawk suzuki or aftermarket 4x4, they all do these types of repairs all the time and will tell you what you need.
