does anyone know.....
  • 1591 Views
« on: April 09, 2011, 07:46:23 AM »
Does anyone know how to hook up a speedometer on a 87 sammy. they did a engine wsap and put in a 94 swift motor, and now i have no speedometer..
Offline Capt
  • 738
  • 28
Re: does anyone know.....
« Reply #1 on: April 09, 2011, 08:02:26 AM »
My 87 Sammy has a regular Speedo- Cable running from the transfer case to the dash panel (Mech. Drive)
My dash has the Tach/Speedo. Also the round air vent style dash.
CAPT
Offline CAMISAMI
« Reply #2 on: April 11, 2011, 05:48:13 AM »
check the cable coming from the transfer case to the speedo make sure the cable turns ok and the sheath is good if it is probably have a bad speedo[ could also be the gear in the t-case]
Offline Jluck
  • 1389
  • 40
« Reply #3 on: April 11, 2011, 05:58:45 AM »
What there saying is. The motor swap should have nothing to do with the speedometer. Should work exactly the same as it did with the original motor. May have been put togeather incorrect after the swap or as the other posts indicated.
Offline CAMISAMI
« Reply #4 on: April 11, 2011, 07:58:01 AM »
YES! what jluck said.
Offline grats
  • 28
« Reply #5 on: April 11, 2011, 10:30:56 AM »
or the Sammy speedo is mech driven and the other one is elec from the computer,
which means you need to swap speedos.
1982 SJ410
1997 Tracker
2008 SX4
  • 4314
  • 167
« Reply #6 on: April 11, 2011, 11:49:01 AM »
A 94 Swift is also a mechanical speedo.
