Is the 2.5 a interference type engine ?
  • 4087 Views
« on: August 14, 2010, 07:06:25 PM »
I just purchased a 2001 GV with 2.5 V6 with 106,000 miles . It's in great shape with no rust.I'm just wondering if I should go ahead and replace the timing chain.Also do the 2.5 require valve adjustments like the 1.3 s in the sammy's.
Re: Is the 2.5 a interference type engine ?
« Reply #1 on: August 14, 2010, 11:30:49 PM »
I'm not sure, but I think it is, and why I think they put
a chain in that engine instead of a belt
« Reply #2 on: August 15, 2010, 08:06:33 AM »
The 2.5 is an interference engine and has I believe three timing chains - before doing anything else, listen to it from a cold start - if you don't hear the chains rattling, then don't worry about them.
If you do hear them rattling, start with an oil & filter change, 10w30 or 10w40 depending on where you are, and see what that does for the rattle - a few seconds is fine, anything longer than that - say more than a minute is cause for concern.
The valves don't require periodic adjustment - it has hydraulic lifters.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #3 on: August 15, 2010, 08:37:22 AM »
Yes, Looking at my chilton book that is interfierence                                   Good luck
« Reply #4 on: August 15, 2010, 10:38:09 AM »
Use 5-30 oil, not 10-30 or higher, the heavier oil has been reported
to cause chain stretch in these engines, presumably from excessive
pressure on the chain tensioner
