Hard Hot Clutch
  • 1294 Views
Offline AndrewK
  • 81
  • Of COURSE the ice is thick enough..
Hard Hot Clutch
« on: April 07, 2010, 11:24:19 AM »
Hey guys,  im having a bit of an issue with the tracker.
When everything gets warmed up, (atleast an hour of road time)  It doesnt like to get into gear.  It takes a full force shove to get it into gear. especially first.   My first idea was the clutch cable I installed last fall, but it is all perfect when starting out for the day.
Also when going into reverse, it makes a loud CLUNK, which you can feel just as much as hear.
Any ideas?
97 Geo Tracker.  4x4.  5 Speed.  235/75/R15 ATR's, on Cragar 15x8's (a.k.a Jet Puffed).  Custom tubular safari rack. Custom light bar, 4x Baja spots.  Bedliner interior on its way..
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
Re: Hard Hot Clutch
« Reply #1 on: April 07, 2010, 11:29:43 AM »
sounds like its out of adjustment when it warms up parts expand and the clutch is on releasing all the way   check your free play when its all warmed up
Re: Hard Hot Clutch
« Reply #2 on: April 08, 2010, 07:10:45 AM »
If you shut the engine off, will it go into gear easily?  If so, it is probably the clutch itself.....assuming the clutch cable is good and adjusted properly.
