trans oil '93 geo
trans oil '93 geo
badkat
6
trans oil '93 geo
June 10, 2010, 01:29:27 PM »
just recently put clutch in i went to put oil that we caught back in wouldn't hold but half of it started running out
is the plug on side of trans the only place where you fill it or recon somebody just over filled it
thanks
badkat
6
Re: trans oil '93 geo
June 11, 2010, 11:15:05 AM »
anybody know
c10long
39
June 14, 2010, 01:26:49 PM »
80-90w gear oil. non-synthetic GL-4. is what the factory calls for. GL-4 has been replaced with gl-5. So, GL-5. Synthetic oil has smaller particals and some say it can seep out through your seals. personal preference.
badkat
6
Reply #3 on:
June 14, 2010, 09:35:06 PM »
also iwent wheeling and the clutch started not disingaugeing al the way i tighting the cable till it ran out still not right
new clutch any susgesting?
c10long
39
Reply #4 on:
June 15, 2010, 06:20:52 AM »
check the clutch arm. the part that connects to the transmission with the cable on the bottom. make sure that isn't stripped or it slipped.
badkat
6
Reply #5 on:
June 15, 2010, 09:55:52 AM »
thanks for your help man!!!! i found the outer part cable was broke making it not pull the arm far anough
Drone637
8121
116
Evil Cow
Reply #6 on:
June 18, 2010, 09:41:20 AM »
As for the oil coming out of the side, that means it's full. You only fill it up to the fill plug, same with the transfer case.
