[/quote]
Or by a hamfisted hammer mechanic. I've been using a 3/8ths drive ratchet in my Zuk plugs since I've owned it. There still fine.
[/quote]
I would agree with you because the PO of my samurai tightened everything down as if no one would ever need to get things off, lol, when i went to use my 3/8s drive end on my fill plug it about stripped it out, if it gives me trouble after i get the square head end then i will heat it up a little with a torch (without heating it up too much not to get the oil too hot) and bang on it a few times and then try it again.
Does anyone recommend any products you can apply to fill and drain plugs as to not make them so hard to get back out, like an ANTI sieze lube?
