Changing differential fluid. How? What type of fluid?
  • 63 Replies
  • 29499 Views
Re: Changing differential fluid. How? What type of fluid?
« Reply #60 on: March 15, 2012, 04:01:08 PM »
Some heat will sometimes help it break loose.  Otherwise it's just a lot of time with a pipe wrench.
Offline megaton
  • 87
« Reply #61 on: March 15, 2012, 06:31:32 PM »
Thanks Drone. I do have a pipe wrench somewhere. If I do get them out, do you know where I can buy some new ones?
« Reply #62 on: March 15, 2012, 08:30:55 PM »
I would give Trail Tough a call.  They picked up Hawks old inventory so chances are they will have one.
Offline 86Sumo
  • 27
« Reply #63 on: April 13, 2012, 04:33:24 PM »
Hey all, I use a suction gun to fill the cases with oil. It's cheap and works great. Kinda messy but no more than pouring it in.
 It looks like a grease gun except where the pump on the grease gun is, the suction gun has a hose. You can suck the oil out of the jug and squirt it into the fill plug hole. Then I store it in a garbage sack because gear oil will get on everything. Also the sack keeps it clean for next time.
Bob
