taking the doors off, bolts are stuck GOOD and tight.
  • 23 Replies
  • 3523 Views
Offline jow003
  • 403
Re: taking the doors off, bolts are stuck GOOD and tight.
« Reply #15 on: May 20, 2010, 08:12:36 AM »
ill add that to the list of things to do during the SPOA... not much off track haha
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline MadMaxZuki
  • 77
« Reply #16 on: May 21, 2010, 03:34:57 PM »
i had trouble with plan B, the heat wasnt enough. i also had bad luck with the impact driver. i found an impact drill works the best. turn the bolt into a flat head and get a 5/16 head and use an impact drill.
88.5 Samurai 33" TSL, 6.5:1 Xcase Gears, 92" wheelbase, 3link rear, SPOA front w/ drop shackle, open/locked. Soon to be this spring: Toyota front and Dana44 rear w/ homemade offset.
Bobthebiker
« Reply #17 on: May 21, 2010, 03:45:28 PM »
My drill is a hammer drill, which basically pounded it into submissin and got the screws loose MY WAY.
« Reply #18 on: May 31, 2010, 03:19:59 PM »
Figured I'd try it...  Took the DeWalt Hammer-Drill and a #3 bit...  Came out like they were never tight at all...  Guess I got lucky...
Offline woof359
  • 111
« Reply #19 on: May 31, 2010, 03:58:35 PM »
i found on the last 2 I had once you drill off the head the blts unscrew, its the head putting torque on the threaded part. no impact driver, youll dent the fender big time !!!!
CHUCK AND MICHELLE
Offline jow003
  • 403
« Reply #20 on: June 01, 2010, 05:24:58 AM »
this weekend i bought a shiny new 3lb hammer, combining that with the impact driver and all 8 screws came out almost like someone had loosened em for me.
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline TopHeavy96
  • 488
« Reply #21 on: June 01, 2010, 05:16:42 PM »
I think part of the problem with the impact driver is that alot of people think you just have to smack it.  Actually, you gotta apply some torque in the direction you need it to go, then smack it.
Offline doughboy0379
  • 290
  • 9
  • Blinker fluid is free so use it........
« Reply #22 on: June 02, 2010, 03:19:33 AM »
When I did my doors I cut both sides of the screw then but vise grips on to what was left, I then put in normal hex head bolts.
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds :)
Offline jow003
  • 403
« Reply #23 on: June 02, 2010, 05:09:28 AM »
Ya, if youve never used one before it takes a little while to get the hang of it, the ticket for me was buyin a big |removethispart|@$$ hammer, my standard sized hammer just wasnt heavy enough
87 Samurai...
5" SPOA/OTT -RRO
1" shackles
33x1250x15 MTZs
15x8- DC-2s
