HELP! Fluid in right rear drum
bbutler455
163
2
1986 Samurai, 1.6L8V TBI, AC, headers, OME
November 01, 2012, 05:44:43 PM »
I finally got the rear drums off... and there is fluid in the right side drum. The brake cylinder seems in good shape and the brakes are holding preasure. Is there a differential seal I should check? I couldn't find anything in the service manual.
Brock
1986 Samurai with Suzuki removable hardtop, 1.6 8V TBI, Vintage Air, OME springs, 235/75 tires
Skyhiranger
3734
122
I don't buy, what I can build
Re: HELP! Fluid in right rear drum
November 01, 2012, 05:59:45 PM »
Yes, there is a seal in the end of the axle tube, on a samurai axle.
Is the fluid gear oil, or brake fluid? Both have very distintive smells, so it shouldn't be hard to tell.
Tan Zuk
562
8
November 01, 2012, 06:15:03 PM »
Here is a good thread on replacing the seal
Link
http://www.zukikrawlers.com/showthread.php?t=2905
warbird
110
2
Reply #3 on:
November 07, 2012, 10:35:55 AM »
Either way (Brk fluid or gear oil) you probably need new brake shoes (and the drum will need a really good cleaning). Since brake shoes come in sets of four you might as well plan a rear "brake job" too (after you eliminate the leak).
