Front diff gasket or.....
  • 1246 Views
Offline RalphARoni
  • 83
« on: November 24, 2019, 10:23:58 AM »
Hi
 I plan to replace the oil pan gasket which I am told will involve dropping the front diff to get the pan off. That is OK since the diff leaks anyway. Someone here said that the dif does not use a gasket ans was originally sealed with RTV. I have not used liquid gasket materials for a diff before. Can you tell me which one would be the best? Anything I should pay attention to while I am doing the pan gasket?
'96 Geo Tracker 2 dr auto 4wd 15" wheels, 23" tires, named "GT" and towed behind the motorhome
  • 4314
  • 167
Re: Front diff gasket or.....
« Reply #1 on: November 24, 2019, 04:56:42 PM »
Permatex makes a sealant that is specifically for use with gear oil, that would be my choice.
Offline JollyZuk
  • 284
« Reply #2 on: November 27, 2019, 08:24:47 PM »
Another option is go to your local Chrysler dealer.  Purchase the grey axle rtv Mopar makes.  It is one of the best RTV products I have ever seen.
1995 Sidekick JLX
OEM ROOF RACK!!!
