Can a 4dr 1991 engine & 5spTrans transplant into 1993 4dr auto??????
  • 1133 Views
Hi i want to transplant my 1991 engine and 5sp trans into a 1993 4dr JX that
has an auto trans 3sp with the over drive. can this be done reasonably?
I have heard I may have to change the complete wiring Harness Is this correct? or
 can I just do the swap and change the ECM.
Does the wiring harness have any connection points that will help the swap??
any info will be appreciated.
MTW
Re: Can a 4dr 1991 engine & 5spTrans transplant into 1993 4dr auto??????
« Reply #1 on: October 29, 2011, 04:54:11 PM »
A 91 4 door has a 1.6 8V engine.  A 93 4 door has a 1.6 16V engine.
You will have to swap the complete wiring harness and ECM.  The wiring harness has sections that unplug, so that will make it a little easier to remove the old and put in the new.
« Reply #2 on: October 30, 2011, 06:17:24 PM »
Thanks,
Sounds like I am in for a bit of work I'll be taking lots of pics before and while I dismantle the old one.
MTW
« Reply #3 on: November 01, 2011, 07:35:45 AM »
I'd suggest you disassemble the entire dash in both rigs ...
Getting the 3 pedal assembly in/out will be one of the biggest headaches and I don;t even think it's possible without the dash pulled.
Having the dash pulled also aids tremendously in getting the harness(es) in/out.
