How to make sure intake manifold is good before installing on new motor.
  • 1463 Views
Offline Pinscher62
Hey All,
Is there a way to check an intake manfold before I install it on a new motor?  I want to be certain it is not cracked or warped or anything else before i install it.  Is there any shops that do this type of work? Not sure if this is in the relm of a machine shop.  I just want to be sure there are no cracks that could leak water into my intake valves.
Thanks for your help as usual.
  • 4314
  • 167
Re: How to make sure intake manifold is good before installing on new motor.
« Reply #1 on: January 21, 2016, 05:52:56 AM »
You can check for warping with a straight edge and feeler gauges, but if you want crack/pressure testing you're going to need to build a jig of sorts - flat plate cut to fit and bolt to the flanges, with either a gasket or RTV sealant, drill a hole somewhere and add a Schrader tire valve (get one of the flanged screw-in ones for alloy rims), pressurize the manifold and immerse it in a tank full of water (try either a radiator shop or a tire repair place).
Apart from possible warping of the flanges, I don't see much else as being an issue - it's not like the intake is a highly stressed part.
Offline Pinscher62
« Reply #2 on: January 21, 2016, 10:28:32 AM »
Awsome! Thanks for the advice. I will give it a shot. Thanks again
