Airbag reset issues
  • 1083 Views
Offline ReeSon
Airbag reset issues
« on: August 06, 2012, 12:10:46 AM »
airbag light started coming on intermittently. It is almost certainly a connection since it goes off and comes on as the road gets rough.
some people tell me to fing one diagnostic tool to reset airbag
i found one call GM Tech2
http://www.uobd2.com/wholesale/new-gm-tech2-scanner.html
but quite pricey
any other diagnostic tool like GM Tech2 but more affordable?
or any guidance for my suzuki SX4 2009 to reset airbag without tool??
  • 4314
  • 167
Re: Airbag reset issues
« Reply #1 on: August 06, 2012, 04:49:13 AM »
If the light is going off then you don't need a reset tool, you just need to find the bad connection and fix it.
Offline ReeSon
« Reply #2 on: August 06, 2012, 06:20:24 PM »
yes it is going off
are there any step to step guidcance??
some friends also said that
there are a $5 APP and a $25 obd2 code scanner just can make things done
the obd2 scanner like ELM327
http://www.uobd2.com/wholesale/elm-327-15v-usb-can-bus-scanner-software-450.html
$30 total..that is so sweet
does it work??
